Old 10-27-2007, 01:54 PM   #1
Question
Flexible propane piping
I want to put in a gas fireplace. I currently have a wood burning fireplace that sits on a concrete slab. We put an outside air source in the floor connecting the fire box to the cellar. It drops 12 inches vertically and then makes a 90 degree turn and goes straight to the cellar. I think copper pipe will crimp and not make the turn. Has any one used or know of a flexible alternative to copper. I use propane from a tank outside the house. I'd appreciate any help you can give me.
shvizdak is offline   Reply With Quote
Old 10-27-2007, 04:50 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Flex alternatives -Flexible copper -Corrugated stainless steel tubing (CSST) it depends on your codes, your experience, etc. CSST 'round here is only sold to the trades, special training, tools, fittings, etc. Your area may be different. Also 'round here they mandate a yellow jacketed copper for gas. Also special tools to do the job and purpose designed fittings. Neither is a job I would counsel a DIYer on unless I knew their skill level. Call a pro.
Brik is offline   Reply With Quote
Old 10-27-2007, 07:37 PM   #3
I have gas!
Clutchcargo's Avatar
You probably are not allowed to do your own gas pipe fitting but if you are here's the product they sell in my local plumbing store.
www.omegaflex.com/trac/res.htm
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Propane heating questions Badfish740 General Discussion 1 09-25-2007 08:46 PM
Flexible pipe for plumbing bigboyjoel Plumbing 2 06-26-2007 12:43 PM
Propane installation for range in kitchen acoustic_bum General Discussion 1 02-14-2007 10:14 PM
Propane Smell sjhandy1971 HVAC 4 01-06-2007 05:54 PM
