Flexible Hose - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2013, 05:52 PM   #1
Flexible hose
I'm installing a new toe kick heater under cabinet. What hose can I use that is flexable n can hold the hot temperature from the water. I've seen that shark bite has n hot water hose that just slips on. Would that be good to use.
ecocco1469 is offline   Reply With Quote
Old 09-09-2013, 06:40 PM   #2
Rewards Points: 318
I would refer to your installation manual for proper hosing. Usually they come with their own flexible hosing all ready to go unless you want a specific type of hosing. What brand did you get? Is it a Myson?
jmon is offline   Reply With Quote
Old 09-09-2013, 07:24 PM   #3
I bought beacon Morris k84. It did not come with hoses or say which to use
Old 09-09-2013, 07:46 PM   #4
Rewards Points: 318
I am not sure if sharkbite would work. It's possible. Have to match it up and see.
This is the one they make for the k84: k84 hose
Old 09-09-2013, 08:48 PM   #5
Rewards Points: 13,950
Pex would also work.
Old 09-09-2013, 08:57 PM   #6
dannyoung85's Avatar
In commercial hydronic systems it is common to use threaded stainless steel woven wire flex connects at equipment connections. It would be similar to an appliance connector. What size of a hose do you need?
dannyoung85 is offline   Reply With Quote
Old 09-10-2013, 04:47 AM   #7
Is the hose ur talking about. The same as the one u hook up the hot water under sink. Will that b strong enough to hold the hot water n pressure for the toe kick
Old 09-10-2013, 04:37 PM   #8
I want a hose so if I ever need to pull it out I could
Old 09-10-2013, 05:00 PM   #9
It should be fine. Check the tag on the hose to make sure you are within the recommended temperature and pressure rating.
Repairing Garden Hose Connection cl6120 Plumbing 9 09-12-2012 09:20 AM
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 12:51 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
Flexible Dryer Vent Hose JLT Appliances 7 12-07-2009 09:52 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
