Flexible Gas Lines Behid Walls, Up To Code? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2009, 11:46 AM   #1
Rewards Points: 150
Flexible gas lines behid walls, up to code?
I will be having a plumber doing some work in the garage for the heater. He tells me that he will be installing some flexible gas lines which are being currently used in new constructions and are approved for use behind the walls (not under the house). He tells me that this is much easier to install therefore it would cost less. I just want to verify that this type of flexible gas line is up to code and can be used behind the walls. I live in Southern California, so he said that this is a big plus specially when it comes to earthquakes since the lines won't break. Any info would be apreciated. By the way this is a licensed plumber if it makes any difference.
gante is offline   Reply With Quote
Old 03-26-2009, 11:53 AM   #2
HVAC / Plumbing
I don't know what you mean about flexable pipe... Are you talking about this..........http://www.omegaflex.com/trac/home/
kenmac is offline   Reply With Quote
Old 03-26-2009, 12:18 PM   #3
Here's another bundle of info. for your reading pleasure. I have flex-line feeding a gas fireplace. Some of that line is exposed and some is above a drop ceiling. You may want to pay particular attention to protecting the hidden line from damage and to the proper bonding procedures.
http://www.gastite.com/include/langu...8_DI_Guide.pdf
Rivethead is offline   Reply With Quote
Old 03-26-2009, 12:42 PM   #4
HVAC / Plumbing
Yes, good point .. The mfg requirs it to be grounded.........Check with the inspections dept. in your area. They allow it to be installed behind wall.. may not
Old 03-27-2009, 11:14 AM   #5
Registered User
Termite's Avatar
He's talking about CSST (corrugated stainless steel tubing) gasline. It is commonly used nowadays and works great. It does have some seismic advantages over hard-piping. Electrical bonding is very important with a couple of the major brands. Be sure your plumber pulls a permit to have it inspected...There's a lot of installation criteria involving protection of the pipe itself to electrical bonding to leak testing.
Old 03-27-2009, 01:57 PM   #6
Rewards Points: 150
The plumber never mentioned anything about permits, I assume he has no intention of getting one. This job will only be to redo some of the plumbing from the house to the detached garage. He is planning to use this "flexible" piping in the garage only. This will feed the heater and gas dryer only. Will this require a permit?
Old 03-27-2009, 02:08 PM   #7
HVAC / Plumbing
While I don't know what they require in your area... Here any leak repairs etc, no permit... Running new gas lines require permit.... Of course, permits are a hassle at tmes & cost $
Old 03-27-2009, 02:36 PM   #8
Registered User
Termite's Avatar
The plumbing code absolutely requires a permit for installing any new gas line.
As for hassle...
How much of a dang hassle is it to properly leak test a new section of pipe and to install it the way it is intended to be installed? A plumbing permit is inexpensive when you're getting an advocate to ensure that you're getting what you pay for and that it is done safely.
If your plumber doesn't want to get a permit, find someone more responsible that isn't willing to compromise their integrity or your safety by flying below the radar and avoiding the minimum standards set forth by the code.
I hate it when anyone even eludes to evading building permits.
Old 03-27-2009, 03:18 PM   #9
HVAC / Plumbing
I know you are a inspector & a mod... But, just because someone doesn't get a permit / inspection doesn't mean they don't go by code (proper testing, installing ,etc,).... Some areas don't even have an inspections dept..I also understand / know that an insection is there to protect John Q. Public so, I not aganist it...Some of my best friends are local inspectors
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
Basement Electrical- Flexible Conduit? H Thomas Electrical 2 04-20-2006 08:42 PM
