Old 02-13-2009, 10:03 PM   #1
Flexible gas line
I live here in Wisconsin and am going to change out my gas water heater. Currently the gas hookup is done with black pipe. The last time I changed out a gas water heater I had to replumb the pipe so that it lined up with the new valve. Can I use flexible gas line to make the final connection to the valve instead of having to repipe everything.
Steelhead is offline   Reply With Quote
Old 02-13-2009, 10:38 PM   #2
Flexible gas line
If your talking about regular flex line - no - you cannot use it to feed the water heater.
You can use black pipe with the sediment trap from the tank up to a point you can securly connect it. From there to the main black iron you can use CSST flex line to make your connection. Installing CSST requires specific cutting tools and connectors. You need to be certified to install it.
Rivethead is offline   Reply With Quote
Old 02-13-2009, 10:51 PM   #3
Flexible gas line
I'm talking about flexible line (I've seen it at Lowes) that is used for dryers and stoves. On the bag the line was in it said this line could be used for water heaters as well. Would this be okay?
Old 02-14-2009, 12:40 AM   #4
Moderator
Termite's Avatar
Flexible gas line
It would absolutely be just fine and code-legal to use a pre-made flexible gas whip to connect your water heater. You must have a shutoff valve on the piped end of the whip, but no union is required.
Old 02-14-2009, 01:13 AM   #5
Flexible gas line
I believe "legal" will depend on your jurisdiction and who inspects the house and for what reasons. Here - the gas company will make you remove it - especially that stuff they sell at Lowes. Flex lines behind stoves and dryers are not subject to the abuse that the line running down the side of a water heater will be. If you insist on using CSST - get true CSST and have it installed by someone with the required certification and who knows how to properly bond and ground it. For your reading pleasure:
Old 02-14-2009, 02:01 AM   #6
Moderator
Termite's Avatar
Flexible gas line
Jurisdictions and gas companies prohibiting flexible gas whips is the exception, not the rule. It is best to check with your local inspection department before starting the project...You need a permit for the water heater replacement, and it is best to do it the right way the first time.
Gas Line Extension - Can I use Flexible Pipe? MikeinBurien Plumbing 35 10-15-2012 12:58 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Flexible gas line and dryer vent? kcrossley2 Plumbing 5 05-05-2008 12:31 PM
Flexible copper gas line wease Plumbing 6 04-09-2008 11:40 AM
