Old 06-10-2008, 02:50 PM   #1
Default Flexible Copper or Rigid Copper?
I'm connecting solar panels, running glycol (closed loop). The loop has to be copper as the panels & fluid can reach up to 300F in the unlikely event there's a power failure at sunny noon time. If power comes back the system will kick on sending up to 300F fluid through the lines. Pex is out. I can't find anything if flexible copper would be okay or not, it would be a heck of a lot easier to run it in the attic than soldering stretches of rigid pipe plus glycol is thinner than water, and will leak in places water will not so the fewer joints likely the better. Know if there's any downfall to flexible copper?
Piedmont is offline   Reply With Quote
Old 06-10-2008, 03:40 PM   #2
Building codes guy, Mod
thekctermite's Avatar
The 300 degree temperature would concern me with rigid copper and soldered fittings.
You should post in the HVAC section to get help from a solar guru!
thekctermite is offline   Reply With Quote
More On This Topic
Taking copper pipes apart may be necessary if you're remodeling an older home or if you have a leak between a pipe and a fitting. It's a job the home handyman can handle with the right tools. Just follow the steps below. Read More »
Okay so then if you are doing the copper foil method, remember that we are not talking about the lead cane method today which as I said is used for kind of larger pieces that need a lot more strength. If you are using the copper foil method you will need... Read More »
Now when picking out footwear, one of the decisions you are going to have to make is whether to go with a shoe or a boot. And most people think that the obvious answer would be a boot. But not necessarily. This boot just happens to be the most popular at... Read More »
Now a gate is only going to allow a certain sound to play once it reaches above a certain decibel level. So now when using gate you can use it for loops and kind of cut off unnecessary sound and unwanted noise, but you could also set it higher so that... Read More »
On behalf of expertvillage.com, my name is Allison at Western Art Glass. We are talking about soldering sun catchers. We solder the front side and we want nice rounded solder beads. It looks good and it makes your sun catcher stronger. So we don't want... Read More »
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 12:55 PM
Flexible copper gas line wease Plumbing 6 04-09-2008 12:40 PM
Flexible copper in attic space Lmiller Plumbing 1 03-11-2008 10:42 AM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 01:42 PM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 01:05 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
