Flexible Copper Gas Line To Grill - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2012, 10:34 PM   #1
Flexible Copper Gas Line to Grill
Wanted to know whether this type of copper gas line installation to the exterior grill is safe and meets code. I was concerned about the corrosive effects of the natural gas and/or soil on the copper tubing.
mk00 is offline   Reply With Quote
Old 03-30-2012, 10:38 PM   #2
DIY Enthusiast
sublime2's Avatar
I have to same thing running the same way to my grill.
Has been like that since house was built.(40 years).
Never an issue for me.
sublime2 is offline   Reply With Quote
Old 03-31-2012, 08:58 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 984
The answer to your question is maybe but closer to no. and by the way that copper going through the wall in the picture is not to code.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-31-2012, 09:42 PM   #4
DIY Enthusiast
sublime2's Avatar
For new installs I'm sure it is not.
Like I said,mine was done over 40 years ago..
Old 04-01-2012, 12:00 AM   #5
Rewards Points: 12,830
Now they use a yellow PVC coating on the copper when it runs under ground.
Your going to need a real flex line from the shut off valve to the grill.
Old 04-01-2012, 10:47 AM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 984
I assumed that, but hereís the thing just because it was done like that 40 years ago doesnít clear you of any problems. The codes have been upgraded from trial and error and incidents. That gas line going through the block was ok 40 years ago, but what we have learned over the years is that copper in contact we different materials one plaster/cement/mason /corrodes the copper. you may pull that line from your wall and itís in perfect condition, but in another case it could be corroded, imagine a leaking gas line in the block sealed with calking, check it if the copper is good just make the hole a little bigger and put a piece of pvc pipe around it as a protected sleeve then seal booth ends, just a safety issue
Tags
gas line
Gas Line Extension - Can I use Flexible Pipe? MikeinBurien Plumbing 35 10-15-2012 12:58 PM
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 05:32 PM
Service #4 copper main feed line price? Big Scaper Electrical 6 12-12-2011 09:19 PM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 03:29 PM
Flexible gas line Steelhead Plumbing 5 02-14-2009 02:01 AM
