Old 12-05-2006, 08:00 AM   #1
Flexible copper gas line
I'm adding a gas fireplace to my master bedroom. The length from the gas meter to the fireplace will be 130 feet. Wondering if they sell flexible copper that long. I haven't seen it in any of the home improvement stores. Can you connect shorter lengths with flare unions? Or is there a better way? Thanks.
wease is offline   Reply With Quote
Old 12-05-2006, 08:38 AM   #2
alot of places don't allow Flex copper as a gas line...... Check local building code first!!! I'd thnk if it's allowed you'd have to join 2 pcs as the longest i've seen at the "bix box" stores is 100'
mdlbldrmatt135 is offline   Reply With Quote
Old 12-05-2006, 08:41 AM   #3
Both of my furnace lines are flexible copper. I would assume that to mean it is ok to use per code?
Old 12-05-2006, 10:23 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
You can asssume that, but you still need to contact your Building Inspection Department to double-check code, permit and inspection requirements, etc. before any work.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-05-2006, 11:14 AM   #5
Does the IFGC allow use of flexible copper for gas lines?
Old 12-05-2006, 11:45 AM   #6
Ok, I called and it is allowed. I can also use flare connectors if the space where they are installed is accessible. But, I still wonder where I can get a long length of it to avoid flare connections.
Old 04-09-2008, 11:40 AM   #7
http://www.copper.org/copperhome/Hom...gas_systm.html
brada is offline   Reply With Quote
Gas Line Extension - Can I use Flexible Pipe? MikeinBurien Plumbing 35 10-15-2012 12:58 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
