Flexible Copper In Attic Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2008, 08:01 AM   #1
Flexible copper in attic space
Im putting in a new shower with some body jets. Instead of trying to turn a corner with rigid copper being worked through the corner studs, I was going to drill a hole in the top plate in between studs, run flexible copper into the atttic and back down the wall where I want the body jets to be. Then solder on a coupling and go back to rigid copper. Any problem with doing that? Anything a newbie should be aware of first?
Thanks for the help!
Lmiller is offline   Reply With Quote
Old 03-11-2008, 08:42 AM   #2
RippySkippy's Avatar
Would freezing be an issue where your at? I don't think I want anything to do with water in the attic in a cold environment.
Convert from rigid copper to pex, bend your corner, take the pex to the jet.
RippySkippy is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Flexible copper gas line wease Plumbing 6 04-09-2008 10:40 AM
Attic Venting/Insulating Question gregt848 Building & Construction 1 11-25-2007 02:33 PM
Birds' nest in attic crawl space Frances Pest Control 1 09-01-2007 04:48 PM
rats is my crawl space and in my attic this old house Pest Control 5 06-02-2007 05:48 PM
