Flexable Supply Lines For Water Softner Any Good? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 08:45 PM   #1
Rewards Points: 77
Flexable supply lines for water softner any good?
Hooking up a new softener today. The new softener lines up a little to the right of the old supply lines. I'm considering just using the flexible stainless steel lines like the one in this picture. Any onions on if these are really the best way to do it? Just wondering if the pro's actually use these things.
nateo is offline   Reply With Quote
Old 03-16-2013, 09:01 PM   #2
Rewards Points: 13,270
Nothing wrong with them.
Old 04-03-2013, 07:16 PM   #3
Metal
I'd go with metal personally. In the long term I think that metal is the safer option over plastic - even if it's food grade. Possible a better connection too.
plumbthat is offline   Reply With Quote
Old 04-03-2013, 10:58 PM   #4
Rewards Points: 243
I used corrugated stainless steel lines made by falcon stainless to hook up my softener and I am very satisfied with them.
chemman is offline   Reply With Quote
Old 04-04-2013, 12:42 PM   #5
Flexible plumbing lines
As long as they're installed properly, there's no problem with using flexible lines.
AmandaPeters is offline   Reply With Quote
Old 04-04-2013, 12:47 PM   #6
Plumber from London
lead pipes are to be avoided
you can use stainless steal pipe or plastic
LondonPlumber is offline   Reply With Quote
plastic water supply lines macwall Plumbing 5 07-04-2008 08:43 AM
3 supply lines for sink rockybottom Plumbing 5 01-25-2008 09:25 AM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
Old Water Supply Lines in Kitchen and Bath Faucets skittlzski Plumbing 2 08-08-2006 10:13 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
