Flex To Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2007, 03:48 PM   #1
Flex to Water Heater
Is flex gas piping allowed on water heaters in a residential setting?
If for whatever reason the answer is no, can you please give a code section and reasoning why not?
Thanks in advance
darcarcr is offline   Reply With Quote
Old 01-11-2007, 06:11 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You you can use gas flex line to tie gas line to a water heater.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 06:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
