Flex Line From Black Pipe To Appliance - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2008, 02:22 PM   #1
Flex line from black pipe to appliance
Should these connections from black pipe to flex line and flex line to appliance be doped or is it special (compression fitting?) and doesn't require dope or tape?
kennethjyoung is offline   Reply With Quote
Old 02-20-2008, 07:24 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
It's a ground joint, no dope needed.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-20-2008, 07:38 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
There you go again, Ron ole buddy. Ruining all of my "silicone and duct tape" plumbing advice. LOL
Mike Swearingen is offline   Reply With Quote
Old 02-20-2008, 07:39 PM   #4
Journeyman Plumber
I do my best Mike.
Old 02-21-2008, 06:26 PM   #5
OK. No dope on either end of the flex line on the connections to my new gas water heater and range. I hope I don't blow up my house. Thanks Ron. And thanks Mike (sort of).
Old 02-21-2008, 10:21 PM   #6
Rewards Points: 884
Hopefully, with the addition of new gas appliances you've sprung for new gas flex lines, right? Read the directions - use no pipe dope.
LawnGuyLandSparky is offline   Reply With Quote
Old 02-22-2008, 09:22 AM   #7
Oh, the directions. I'll try that. I haven't bought the flex lines yet. If they come with install instructions that will be my bible. Thanks.
Old 02-22-2008, 03:38 PM   #8
I blame ProWallGuy
Rewards Points: 150
Clean, clean and clean. Those are the three rules of putting a flared joint together, which is the type of ground metal joint you're putting together.
Do use two wrenches, one to tighten with and one as a backup to prevent something turning that you don't want to turn. Sometimes regulators are attached to appliances inside where we can't see them on flimsy brackets that bend easily.
Double A is offline   Reply With Quote
Old 02-24-2008, 06:53 PM   #9
Rewards Points: 150
well IF Ron is such a good plumber,,,I wish he would fix that leaky faucet in his pic,,,its driving me NUTS!!!
justdon is offline   Reply With Quote
Old 02-24-2008, 07:21 PM   #10
Custom Cabinet Maker
Only dope is on the wrench
And YES I am included
skymaster is offline   Reply With Quote
Gas Line Extension - Can I use Flexible Pipe? MikeinBurien Plumbing 35 10-15-2012 12:58 PM
Repairing black poly pipe MelAuston Plumbing 4 10-31-2007 09:54 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
Flex Gas Line Babybird HVAC 1 02-14-2007 07:32 AM
