Flex Hoses Able To Be Tightened Or Pressed In Place? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2011, 12:32 PM   #1
Rewards Points: 14
Flex Hoses Able to be Tightened or Pressed in Place?
I've got two of these faucets that were put in place by a contractor before I purchased my home. They're only a few months old, but they've both started to leak from underneath where the flex hosing meets the faucet. However, the connection is so far down that I can't really tell if the hoses are pressed in place or if they can be tightened with some sort of special wrench that I haven't been able to find.
Thanks!
WillJohnston is offline   Reply With Quote
Old 02-26-2011, 12:59 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,288
Is there a brand name like Delta or Moen on them?
Old 02-26-2011, 01:07 PM   #3
Builder/Remodeler
ChrWright's Avatar
They are threaded in, with rubber o-rings.
They are normally just hand-snugged. If you don't hold the line stationary while connecting the other end to the shut off they can end up getting loosened.
Clockwise into the faucet body should stop the leak. If not, you may have to remove them and replace the o-ring. It's possible a ring was damaged or missing.
ChrWright is offline   Reply With Quote
Old 02-26-2011, 03:14 PM   #4
Rewards Points: 14
Thanks so much! Looks like it's back to work with me.
Old 02-26-2011, 03:39 PM   #5
Learning by Doing
Leah Frances's Avatar
I have seen several leaks when the O-ring was never installed. My buddy's sink was leaking and he asked me to look at it for him (poor shmoe doesn't even own a screwdriver). It was leaking at the junction. The O-ring was still in it's little plastic bag.... taped to the flex hose.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-04-2011, 08:09 PM   #6
Rewards Points: 14
Okay, so I was able to unscrew them, and everything looked fine. I snugged them back up, and everything was fine for a day or so. Then they started leaking again. Would some sort of pipe dope help?
Thanks for all of the advice! Really appreciate it!
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 08:15 AM
