Old 11-18-2012, 10:49 AM   #1
flex gas piping for a gas dryer comming off the feed to the furnace
what can I bond the flex gas pipe to. a lighitng rod ground? the elcectrical panel is too far away.
george mcmillen is offline   Reply With Quote
Old 11-18-2012, 11:00 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Not following what you are asking about.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-18-2012, 01:03 PM   #3
If you're just adding on to your gas piping, the existing piping should already be bonded. Check outside by the meter, or perhaps in the mechanical room.
hvac benny is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
