Fleck 5600 - How Much Resin Do I Need? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2011, 10:58 AM   #1
Talking
Fleck 5600 - How much resin do I need?
I am attempting to assemble my fleck 5600 and it came with 2 boxes of resin. I also ordered the Canpro-455 filtration cartridge. The boxes are labeled high efficiency and soft resin. I read somewhere that one of these resins acts like a gravel and needs to be placed at the bottom of the tank.
1. How much of each resin do I need to pour into my tank?
2. How much room should I leave from the top of the resin to the shoulder of the tank?
3. Does the Canpro-455 being installed affect how high I should pour the resin?
Thanks in advance.
jpp977 is offline   Reply With Quote
Old 11-13-2011, 01:09 PM   #2
I suggest you contact your supplier for directions how to assemble the softener.
As a general comment--gravel is sometimes used and if used it is put in the bottom of the resin tank. The quantity of gravel is determined by the size of the resin tank.
The amount of resin used is determined by the size of the resin tank. There must be sufficient space above the resin to allow the resin bed to expand during backwash without washing resin out of the tank.
You supplier should have provided the correct amounts of gravel and resin but if you have doubts you should go back to the supplier to confirm the correct quantities.
Bob999 is offline   Reply With Quote
Too much resin in my water softner resin tank? Asathd Plumbing 16 07-16-2011 06:07 PM
Resin backed aggregate marble or ??? BJM Tiling, ceramics, marble 8 08-10-2010 09:04 AM
outdoor cement bench rsclark67 General DIY Discussions 11 02-01-2010 07:51 AM
real full stones and resin countertops design511 General DIY Discussions 2 06-04-2009 01:11 PM
Paint and resin coat countertop elliott Painting 5 11-21-2008 01:21 AM
