A "Flare" Tool For Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-03-2009, 03:43 PM   #1
A "Flare" tool for pipes
Hello,
Years ago my Dad had a tool that he used for broken small bore pipes, usually copper. He would fit a male and female nut unit over the respective broken halves, then use an tool to flare the broken ends, and finally thread the nuts to restore pipe integrity. The tool and nuts/bolts came in a set.
Could someone please tell me what kind of tolls/set he used.
Thanks, RHP
arpey is offline   Reply With Quote
Old 04-03-2009, 05:24 PM   #2
HVAC / Plumbing
something like this what you looking for ?? This is only 1 type that is made
kenmac is offline   Reply With Quote
Old 04-03-2009, 05:34 PM   #3
Remodeling Contractor
These are called flaring tools and are used for soft copper usually for gas lines. But for water lines also.
Old 04-03-2009, 09:12 PM   #4
To add to Bob Mariani's post, there is a difference between flare connectors used for gas, water, and high pressure, and there are two different types of flaring tools the one shown above and the double flare tool sets used for steel hydraulic lines.
hayewe farm is offline   Reply With Quote
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 06:02 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 12:41 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 12:34 AM
Tub Drain Removal Tool rjordan392 Plumbing 6 07-08-2008 11:39 AM
