Flapper valve infrequently doesn't completely close
I, just me maybe, particularly don't like those flappers with the float thingy's made onto them. I change a lot of the flapper units out because of the small leaks. I always try to use a really good unit, bought at plumbing supply house, not big box stores. One trick I was taught, and still use, is to use fine steel wool to sort of "polish" the seat the flapper seals to. It seems that sometimes there may be some coating on there which I cannot see nor feel, but the steel wool works. Just a light cleaning with the steel wool, then wipe good with a clean cloth. Inspect the seat really good, I have seen them with tiny chips in them. They are easily replaced. David
