Flapper Leak In VERY Old Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2010, 06:27 AM   #1
Flapper Leak in VERY Old Toilet
I have a 1950's toilet that has a built in overflow and therefore the flapper or ball valve is seating against the porcelain rather than a plastic or metal flange. I would really rather fix this toilet rather than replace it as it is of a color that matches the rest of the fixtures in the room and buying colored fixtures today appears to be extremely expensive.
I've replaced the ball valve several times, switched to a tank floor mounted flapper, and still can't get a good seal. Any suggestions?
Thanks,
Jeff
jlc791 is offline   Reply With Quote
Old 05-25-2010, 06:58 AM   #2
Fluidmaster makes replacement flappers(home/hardware stores) in several configurations that have always worked for me, in old toilets. Are you sure the seat is not pitted or cracked.
Old 05-25-2010, 09:42 AM   #3
I agree with Bill. Many times the seating surface or the flapper gets mineral deposits stuck to it and causes the seepage.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-25-2010, 05:46 PM   #4
Leak Master
Quit wasting time making repairs on older than dirt toilets. If you can afford them, get new toilets. You will benefit with less water usage and no more headaches. I recommend American Standard Cadet III.
O'Leaky is offline   Reply With Quote
Old 05-26-2010, 08:01 AM   #5
Thanks for the suggestions. I will start by cleaning up the seating surface and if that doesn't work, see if one of Fluidmaster's repair kits will work.
O'Leaky - I do appreciate your suggestion and would love to save the water but I have to look at the economic side of things. While a white toilet can be found for around $150, a robin's-egg blue one to match our bathroom starts at $350 and goes up from there. We'd have to be in the house for 10years before the water savings would pay for the difference. (Unless, of course, someone pays for a complete bathroom renovation to convert ALL of the fixtures over to a matching white - you have a spare $15K you're willing to give up??)
jlc
Old 05-26-2010, 10:15 AM   #6
Rewards Points: 590
Always read the entire post, folks!
operagost is offline   Reply With Quote
Old 05-26-2010, 06:52 PM   #7
Leak Master
jlc
I will never understand people and there desire to live in the past or insist that all the fixtures have to be matching colors. I have removed many and varied colored toilets and installed white. Normally they fit in quite well, and most people are surprised at how nice it looks. Especially if there is any white color to your room (walls, floors, counter top, sink etc....).
I apologize, I should have figured that if you were seeking free advice on a DIY site, that you could not afford to pay for a new toilet, but have a lot of free time to waste on repairs.
Old 05-26-2010, 11:32 PM   #8
Rewards Points: 590
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 11:31 PM
Toilet flapper keeps flipping backwards msammut Plumbing 2 07-04-2008 07:08 PM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 11:33 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 03:40 PM
