Flapper Adjustment - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2011, 08:17 PM   #1
Rewards Points: 518
Flapper adjustment
How do I know if my flapper is adjusted right? Should it close before the bowl flushes? How much water should be left in the tank when it closes?
I'm using a brand new Fluidmaster 400AK complete rebuild kit with the red flapper with an adjustable dial from 1-9(9 being max and that's where it's set).
n0c7 is offline   Reply With Quote
Old 01-02-2011, 10:50 PM   #2
if its double flushing, it's letting too much water thru. if it's not then it's ok
the_man is offline   Reply With Quote
Old 01-03-2011, 09:29 AM   #3
Rewards Points: 1,506
It may require some trial and error adjusting the dial on the flapper and observing the results over a few days.
Strategy 1. Adjust the dial so the maximum amount of water is left behind in the tank when the flapper closes but the toilet still flushes reliably.
Strategy 2. Put some food coloring in the bowl. Adjust the dial so the coloring is consistently eliminated during the flush.
Replacing flapper in old toilet joeg679 Plumbing 5 11-11-2010 07:46 PM
burner flame adjustment justplumducky HVAC 0 10-23-2010 06:46 PM
Flapper Leak in VERY Old Toilet jlc791 Plumbing 7 05-26-2010 10:32 PM
Toilet flapper keeps flipping backwards msammut Plumbing 2 07-04-2008 06:08 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 02:40 PM
