Flammable Vapor Sensors On A.o.smith Gas Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 12:42 PM   #1
Flammable vapor sensors on a.o.smith gas water heaters
Mine was accidentally exposed to bug spray in the boiler room.
are these meant to be re- used or do they need to be replaced after 1 exposure? Can it be cleaned in solvent?
Thanks in advance for your advice.
Citireno is offline   Reply With Quote
Old 07-16-2012, 09:36 PM   #2
Rewards Points: 352
replace it you will also need a new seal for the combustion chamber
plumberinlaw is offline   Reply With Quote
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 04:51 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 03:57 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
