Fixture Vent Sizing - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2011, 12:12 PM   #1
Fixture vent sizing
I have a 1.5" pvc pipe that vents my dishwasher and kitchen sink that has to be rerouted. Due to size restrains, using a 1" pipe for the last 3 feet before it penetrates the roof would make my life much easier. Code issues? I want to do this right, not just easy. Thanks
123ozzie is offline   Reply With Quote
Old 11-26-2011, 01:44 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
According to the regs in my area (which typically follows national standards), 1.5" is the minimum for any vent.
ddawg16 is online now   Reply With Quote
Old 11-26-2011, 01:52 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 542
Kitchen sink requires 1.5" vent and you can not decrease a vent pipe size.
Old 11-26-2011, 03:20 PM   #4
Thats kinda what i thought, thanks for responding
Old 11-26-2011, 04:12 PM   #5
Rewards Points: 582
you can't reduce vent stay at 1.5 all the way..
Old 11-28-2011, 08:00 AM   #6
Rewards Points: 3,130
If legal where you live, just forget the vent line and install an air admittance valve in the sink cabinet instead. That's what I did when I built my house.
Old 03-18-2012, 11:04 PM   #7
similar situation for me
Thought AAV's were not code in most places for dishwashers, due to the possible high flow rates. (however this seems bogus to me, with a 1 to 1 1/4" sink drain, a full (8-10" deep min 14x12") sink of water causes massive suction during drainage. How this can be less flow than a 3/4 drainline from a DW is beyond me. Maybe there's another reason?)
mathx is offline   Reply With Quote
Basement branch vent connecting below flood rim of main level fixture benjamincall Plumbing 1 07-13-2010 04:44 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
