Fixing Plumbing With A Hammer - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2012, 10:07 AM   #1
Rewards Points: 2,038
fixing plumbing with a hammer
Even tho I've never had good success with using a hammer it doesn't stop me from thinking, 'this time a hammer will work.' No, it didn't
My sink traps are clogged. Tried to remove them but those plastic rings that hold the pieces together are impossible to remove. I think they must be glued on.
I thought ok I'll just hit the wing part with a hammer and loosen it. Wrong. All I did was break off the wing part.
Any suggestions on getting those things off so I can clean the drain?
thanks
Startingover is offline   Reply With Quote
Old 10-02-2012, 10:12 AM   #2
Experienced
Jackofall1's Avatar
Large pair of channel locks should work
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Startingover (10-02-2012)
Old 10-02-2012, 11:12 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 820
The really large ones also work well for removing oil filters....I call mine my "universal removal tool"
The Following User Says Thank You to ddawg16 For This Useful Post:
Startingover (10-09-2012)
Old 10-02-2012, 04:58 PM   #4
Rewards Points: 79
bigger hammer
or if you want to try to reuse the fittings, a pair of appropriately sized channel locks work well.
eclark is offline   Reply With Quote
The Following User Says Thank You to eclark For This Useful Post:
Old 10-09-2012, 01:41 PM   #5
got it fixed.
Decided to let the plumber do it when he was at the house. I should have peered over his should when he was working so I could see how he did things, but he didn't seem too fond of me on his heels.
Old 10-09-2012, 05:04 PM   #6
Thread killer
Rewards Points: 272
thanks
You went to the "final solutions" drawer right off the bat? That's no fun, you need to be really angry and frustrated for the hammer to work properly in plumbing. That's why you only broke the wing off the fastener
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 10-15-2012, 04:56 PM   #7
canuck, lol
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 09:55 AM
The basics of the hammer iRelate Tools 50 01-24-2012 08:18 PM
Rip Claw Hammer or Curved Claw Hammer? Basketball1234 Tools 6 12-11-2011 09:06 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 10:08 PM
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 09:32 PM
