Old 05-23-2009, 08:10 PM   #1
Fixing leaking shower head...turns out pipe coming out of wall is the source
I removed my dripping shower head assuming I could put in a new 0 ring and fix it. When I got the head off, the pipe coming out of the wall was dripping.
Is this a serious problem? Will this require a plumber?
plumbingboy9317 is offline   Reply With Quote
Old 05-23-2009, 11:17 PM   #2
Hard to tell. The information supplied is insufficient.
The pipe coming out of the wall is controlled by the wall mounted shower control. There should be no water leaving this area unless there's an in issue with the control mechanism.
Post a picture of the shower control. It will cut to the chase.
Do you know what type of control you have? Do you have the installation instructions?
Ron
Ron6519 is online now   Reply With Quote
Old 05-24-2009, 06:17 PM   #3
It is a Kohler system:
First the control knob:
Next the shower head itself:
And this is how they are both positioned:
Any help would be appreciated. Just fyi, Im a novice at this kind of stuff
fixing-leaking-shower-head-turns-out-pipe-coming-out-wall-source-controlknob.jpg   fixing-leaking-shower-head-turns-out-pipe-coming-out-wall-source-showerhead.jpg   fixing-leaking-shower-head-turns-out-pipe-coming-out-wall-source-both.jpg
Old 05-24-2009, 08:19 PM   #4
The closeup of the shower head looks like there's rust coming out of the bottom. Are you on a well or does the house have some galvanized pipes?
Do you have the installation instructions for this shower control? Is it a ceramic disk unit?
If you don't have the paperwork, go online and get it. You will need it to open the unit up and check under the hood. You will need the installation manual. You can also print out the owners manual.
It's possible you have something caught in the mechanism that's allowing water to get through. It could be teflon tape from the pipe rough in or some grit that has made it into the house.
Was the system flushed before the cartridge was installed?
Does the house have a sediment filter system installed?
How old is this installation?
Answering the questions and the manual will help with the diagnosis.
Ron
Old 05-25-2009, 01:16 AM   #5
The only thing I can tell you is that we built this house new in Dec 2002. We dont have a sediment filter. Im not sure if it is ceramic or not.
I did find the product installation guide online here http://www.us.kohler.com/onlinecatalog/pdf/113280_2.pdf
Im going to read through it and see if anything makes sense to me. Let me know if you have any tips.
Thank you
Old 05-25-2009, 02:41 PM   #6
Thank you
Sure I have tips. You need to disassemble the unit and pull the cartridge out. Check the interior of the showerbody for foreign particles. Check the rubber gaskets, o-rings and such for slices, gouges or splits that would allow water to pass the seals.
Check the trouble shooting guide for anything else.
Before you reassemble this, put plumbers grease on all the rubber parts.
Ron
More On This Topic
Sometimes a standard shower head just doesn't do enough. It can't be maneuvered into the right position when someone with a broken arm can't get their cast wet. It can't reach the corners when you clean the tub. It can't rinse all the soap out of Fido's... Read More »
Hey gang, it's Don Golden here for Expert Village and the water is running and we've got to turn it off. I think we pretty much fixed our leaky little problem in here. So what we did was we took this old housing off and replaced our old leaky cartridge... Read More »
Hi! I am Drew Fenn professional home inspector. I am here for Expertvillage.com. Today, we are going to install a shower head and I will show you how and the video is produced by Black Dog Video. You can visit blackdogvideo.biz on the Internet. We are... Read More »
Hey everybody it's Don Golden with Expert Village and we are back outside. Why is that? Because we are almost done with this project. The shower, the cartridge is in and now all we've got to do is turn the water back on and see how it is working. Now I... Read More »
Hi, this is David Foster on behalf of Expert Village. I'm going to go over how to install a shower head, the tools you'll need and take you through step by step on how to do it. First I want to show you the tools that you will need. You need to get... Read More »
very low shower head flow rickard681 Plumbing 8 10-08-2008 07:43 AM
Hi all, leaking internal wall..grrrrrrrrrrrr fridgeman Plumbing 25 09-23-2007 12:39 AM
Water Pipe Size for Double Shower froddan Plumbing 12 08-03-2007 09:46 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 10:05 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 10:19 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
