Fixing Leaking Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2012, 12:37 PM   #1
Rewards Points: 160
The hot water side of my bathroom faucet is dripping. I took the handle off, but I can't seem to loosen the stem to get to the washer. If I turn the large nut, the whole thing moves. There's not really any room underneath the faucet to hold it, so I put vice grips on the lower threaded part and used a crescent wrench to try and turn the nut. It isn't budging. Am I turning the right part? Any ideas to loosen it? I put so much force into it I was afraid it might snap...
matt151617 is offline   Reply With Quote
Old 01-16-2012, 12:54 PM   #2
Rewards Points: 1,594
See next post; arrow missing from this one.
bob22 is online now   Reply With Quote
Old 01-16-2012, 12:56 PM   #3
Use this pic (arrow missing from last post).
I'm not sure; but it looks like the valve stem is held in by an e-clip. Insert a thin, straight-slot screwdriver tip into the area at the arrow, give it a slight twist, the clip should slide out and hopefully, the stem can then be unscrewed ccw. Be careful, the e-clip may go flying (protect eyes) so don't lose it.
You may have to also loosen the next nut beneath the e-clip to get the stem out; I've never seen an arrangement like this but I'm no plumber.
Two handle kitchen Faucet invisible screw: Leaking Faucet chicago7100 Plumbing 11 07-06-2013 01:14 PM
Kitchen Faucet Is Leaking Sycamore Inn Plumbing 23 11-14-2011 03:49 PM
Bathroom Sink Faucet Leaking sgold33 Plumbing 1 01-17-2011 06:16 PM
Leaking anti-siphon faucet (<--help please) dgates12 Plumbing 4 11-07-2010 10:08 AM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 11:08 AM
