Fixing A Leaking Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2010, 09:18 AM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
fixing a leaking drain
I ripped down my old wood ceiling in my kitchen and while it is down I wood like to fix my leaking shower drain. It leaks at the first connection right below the floor. It can actually be moved up and down slighty and if I wiggle it a little after the shower was used a little water will come out. Should This joint be glued. Or could it be missing a gasket. should there be movement? In order to take off tail piece I will need to cut back before the p trap, put a coupling then reattach? Or is there another way to do this?
Millertyme is offline   Reply With Quote
Old 09-12-2010, 10:00 AM   #2
DIY staff
Rewards Points: 7,174
There are two common types of shower drains-----one is a glue up--I think that is what you have.
The other has an opening about 1/2 inch larger than the 2" drain---the drain pipe slides into that--then a rubber ring type gasket is driven into the space between the drain 'cup' and the pipe.
Remove the chrome drain screen and look---if you see a black rubber ring (or some caulk because the installer wrecked the rubber) you will know what you have.
I suggest that you cut that P-trap out ,get a new drain set and rebuild the P-trap-- That is not advanced plumbing--I am sure that you will see the problem and solution as soon as you have it out---Mike
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 04:37 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Leaking bathroom drain. Concrete subfloor... Help crashtah Plumbing 2 05-27-2009 04:42 PM
Bath tub leaking through Drain nitu_752002 Plumbing 5 03-31-2008 09:22 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
