-   -   fixing a leaking drain (http://www.diychatroom.com/f7/fixing-leaking-drain-81225/)
Millertyme 09-12-2010 09:18 AM
2 Attachment(s)
I ripped down my old wood ceiling in my kitchen and while it is down I wood like to fix my leaking shower drain. It leaks at the first connection right below the floor. It can actually be moved up and down slighty and if I wiggle it a little after the shower was used a little water will come out. Should This joint be glued. Or could it be missing a gasket. should there be movement? In order to take off tail piece I will need to cut back before the p trap, put a coupling then reattach? Or is there another way to do this?
oh'mike 09-12-2010 10:00 AM
There are two common types of shower drains-----one is a glue up--I think that is what you have.
The other has an opening about 1/2 inch larger than the 2" drain---the drain pipe slides into that--then a rubber ring type gasket is driven into the space between the drain 'cup' and the pipe.
Remove the chrome drain screen and look---if you see a black rubber ring (or some caulk because the installer wrecked the rubber) you will know what you have.
I suggest that you cut that P-trap out ,get a new drain set and rebuild the P-trap-- That is not advanced plumbing--I am sure that you will see the problem and solution as soon as you have it out---Mike
