Fixing Leak In Shower [Delta Moniter Series 1700] - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2009, 03:17 PM   #1
Cool
Fixing Leak in shower [Delta Moniter series 1700]
This shower was installed when the house was built in 2004. I have no paperwork of any kind. Through many hours of web browsing and talking with Delta, I found that I have a Delta Moniter series 1700 shower faucet. It is leaking at a pretty good clip. Delta is sending me replacement parts. Any tips on taking the valve apart to get at the rubber and springs they are sending? And help will be appreciated.
Paul
paul06 is offline   Reply With Quote
Old 01-03-2010, 10:58 AM   #2
Delta fix?
Usually the Delta shower valves havea chrome 'bonnet' that needs to be unscrewed to get at the 'guts'. After a few years it is usually stuck on pretty good. The bonnet is what the handle lever inserts into. Be very careful because you have to exert a lot of force to get these loose usually.
I'd spray it liberally for a couple days with a good penetrating lubricant like 'pipe-break' before trying to unscrew. Protect the chrome and maybe tap it several times with a rubber mallet and keep you fingers crossed. Counterclockwise, obviously. Try not to overtorque so as to damage the supple lines.
geoffrey hall is offline   Reply With Quote
Old 01-03-2010, 04:22 PM   #3
RE: Delta fix?
Thank you Geoffrey Hall for the tip. I will be on the lookout for that very tight bonnet. Also will pre lube for a couple of days. Thanls.
Paul
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet star987 Plumbing 16 05-01-2011 06:26 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
Shower Leak mcorn Plumbing 4 03-21-2008 02:38 PM
