Fixing A Hole In My Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2013, 12:51 AM   #1
Fixing a hole in my bathtub
Let me first start by saying I am not sure if this is plumbing, but there wasnt a bathroom section that I could see. So sorry if this is the wrong thread.
Let me also say I am a young home owner, and don't have too much experience with plumbing. I am an electrical guy.
My tub recently has developed a hole. I was taking a bath and all of the sudden I swore I heard water falling into my crawl space, and then noticed the water was draining wayyyyy to fast. noitced a hole by the drain.
I am not sure if this tub is porcelain, but I think that is the material. Seems to be metal under the finish.
Is there a way to fix this or do I need to buy a new bath tub.
Nikana is offline   Reply With Quote
Old 01-29-2013, 05:04 AM   #2
DIY staff
Rewards Points: 7,174
That tub is in need of replacing----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
gregzoll (01-29-2013), joecaption (01-29-2013)
Old 01-29-2013, 06:21 AM   #3
You ARE joking with us, right? Plumbing putty should do the trick.
64pvolvo1800 is offline   Reply With Quote
Old 01-29-2013, 07:20 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
That Hole did int happen overnight, tubs gotta go.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-29-2013, 07:42 AM   #5
Rewards Points: 3,130
Replace that tub, or YOU'LL be falling into the crawl space.
Old 01-29-2013, 07:44 AM   #6
Rewards Points: 6,652
Would make a nice planter in your front or backyard. But yep that tub has to go. Now of course, you could probably get away with a Rebath, where they place the insert over it, and go from there. May be easier and cheaper than getting involved with a full bath gut & remodel.
Old 01-29-2013, 07:57 AM   #7
Roofmaster
Rewards Points: 2,210
You better be ready to repair the floor under this tub too. This thing has been leaking for a while. As another poster stated, its a good thing you didnt end up in the crawl space! Didnt you see the rust? Hard to believe.
Old 01-29-2013, 08:34 AM   #8
Rewards Points: 14,312
Anyone here ever used a company like Rebath? It's shocking what they charge for a paper thin liner.
Old 01-29-2013, 08:41 AM   #9
We used a Canadian company to lay a 1/4" poly insert into our bathtub at our rental condo. Very nice job and it's been only 6 months since, so I dont have any long term experience yet. There are approved cleaners and some that are a definite NO-NO.
I'll try to find the name of the product. I think it was about $2400 for the tub only.
Old 01-29-2013, 08:54 AM   #10
So here is the thing I do not understand.
There is no floor under this tub. It is being supported by a metal brace or bracket. I have a feeling this is not normal. how will this affect the repair job.
I saw the porcelin slighly cracked, but it is just one of those things I never made the connection with. I never knew what tubs were made out of, and in my head it was just the finish that was cracked, Like i said, young home owner and never really knew they could get a hole.
Old 01-29-2013, 08:58 AM   #11
Rewards Points: 4,796
It shouldn't have a big effect. I would expect someone would come in and put in a regular subfloor under there before installing the new tub.
jeffnc is offline   Reply With Quote
Old 01-29-2013, 09:00 AM   #12
There are actually different thickness of the liners. But yes, the liners are really no different than most modern day fiberglass or acrylic tubs.
Old 01-31-2013, 01:28 AM   #13
Is that Bathfitters?
$2,400 seems a lot for relining a tub and hiding the problem. A new porcelain on steel tub like the OP has is around $150 - leaves plenty over for a reputable contractor to replace the old tub and fix the floor (which is presumably in bad shape with the leak) plus tiling around the tub, which is what I have to do with a similar problem, unfortunately
Nice car in your username, by the way - is that the same that Roger Moore drove as the Saint in the 60's TV series?
profcolli is offline   Reply With Quote
Old 01-31-2013, 01:37 AM   #14
Roofmaster
How can you have a Tub that is not supported by the floor below???? Water weighs 65 lbs. a cubic foot, plus the tub, plus your weight. The tub is completely shot. The rot is right at the drain. If it were somewhere else, maybe you could redo it, but this thing has been leaking for a long time from the looks of it. But what the heck do you meant by the tub is not supported by the floor?????
Tags
bathtub , hole
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 05:55 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Whats the deal with Hole Saws (price!!)? L4nce0 Tools 5 09-29-2010 09:10 AM
fixing hole in a dresser usta5point0 Carpentry 1 04-17-2009 03:35 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
