Fixing Delta Faucet 1400 Series - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2010, 09:09 AM   #1
fixing delta faucet 1400 series
my delta faucet was dripping. I change the seat and spring and the leak is worse now than before. what else could it be
skcong is offline   Reply With Quote
Old 07-03-2010, 05:33 PM   #2
Rewards Points: 1,668
The cartridge if it has one.
bob22 is offline   Reply With Quote
Old 07-03-2010, 10:20 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
A Delta ball faucet is adjustable. Remove the handle (you don't have to turn off the water.)
There is a plastic ring with two small gaps around inside the cap where the stem sticks out. If you don't have the Delta tool with the little prongs that fits into to those two gaps, you can use the ends of a needle-nose pliers.
Turn it clockwise to snug it down onto the seats-and-springs only so that it quits leaking. Do not over-tighten it as that will just make it hard to operate and wear out the seats-and-springs much quicker.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 04:02 PM
New Delta faucet drips Ultrarunner2017 Plumbing 10 02-28-2012 09:34 AM
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet star987 Plumbing 16 05-01-2011 05:26 PM
delta 1400 series wrbdiy Plumbing 2 01-18-2009 11:56 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
