Fixed Water Leak Not Drying Under Tile Floor Around Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2013, 04:34 PM   #1
Fixed water leak not drying under tile floor around toilet
A month ago I repaired a leaking wax ring around the toilet and 3 days ago there was a leak again that we assumed was the wax ring failing again, but it ended up being the water line leaking at the attachment to the toilet. A fair amount of water leaked around the toilet (tile floor) and there was some swelling in the dry wall seams in the ceiling below (maybe 2 inches wide by 18 inches long. I turned off the water (stopped the leak), opened the ceiling below and have been using a hairdryer to ventilate the ceiling/under the floor, and a box fan to try to dry the tile in the bathroom, but the tile is marble and it is darkened for about a 2 foot radius around the toilet and it has not gotten better at over the last 2 days. I am afraid that the leak was into the wood between the floor and tile and will not dry. I don't want to take the tile up if at all possible.
Thank you in advance for any suggestions.
WinstonWolf is offline   Reply With Quote
Old 05-19-2013, 05:40 PM   #2
Just call me Andrew
Rewards Points: 1,020
The tile may have just been stained....natural stone is pourous and can stain with exposure to water. Does anything feel wet?
Andrew
secutanudu is offline   Reply With Quote
Tags
ceiling repair , marble flooring , mold prevention , toilet leak
leaks on rear base of toilet & water supply valve Nospammer Plumbing 1 08-16-2012 04:21 PM
Need Advice on how to Correct Low Water Pressure Joe Tilghman Plumbing 51 04-13-2012 01:11 PM
Water collecting beneath Tile Jeffs72a Flooring 2 06-04-2011 05:42 PM
leak in toilet tank and water suply Ramcatt Plumbing 3 09-03-2010 10:16 AM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 01:31 PM
