Fittings For Kitchen Sink Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2011, 04:31 PM   #1
Fittings for kitchen sink drain line
I had to replace part of the old cast iron pipe and am wondering if I can just glue this 2" to 1.5" bushing into the sanitary t or if I need to use some pipe and a connector for the bushing, it doesn't seem like the T had a perfect circle for the bushing to fit into, although it does seal, just not along the whole length of bushing. Only reason i'm asking is because i'll have to cut out more of the joists to use the connector. Here are some pics of the pieces i'm taking about.
Bill
I have two different 2" connectors too one was listed for schedule 40, the other dwv, the pipe I have is branded charlotte schedule 40 dwv so i'm guessing I can use either, this line and vent is only for the sink, disposal and dishwasher.
banjo is offline   Reply With Quote
Old 04-23-2011, 06:23 PM   #2
DIY staff
Rewards Points: 7,174
Sanitary Ts are available with an 1 1/2 inch opening---2x2x1 1/2----use that.
However if you want to glue in a bushing instead---go for it.
---Post a picture of the plumbing that need replacing---then we can offer the best suggestions.--Mike--
Old 04-23-2011, 07:28 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 682
the coupling and bushing you have are sch 40, designed for pressure systems such as water. Your tee is for drainage.
Buy a reducing tee as Mike suggested or get a dwv bushing, it's not as long and is designed for your tee
Old 04-23-2011, 07:28 PM   #4
I think that 2x2x1 1/2 T sounds like my best bet but here's a pic of the pipe that's getting replaced. I have already braced and cut the cast iron out and I think i'm going to drop the drain line almost a foot so I can install a garbage disposal.
Thanks,
Bill
The Following User Says Thank You to banjo For This Useful Post:
oh'mike (04-24-2011)
Old 04-24-2011, 09:19 AM   #5
Owner
LateralConcepts's Avatar
While you're at it I'd get rid of that piece of lead...
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 10:56 AM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
