Fitting A Water Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-29-2011, 03:54 AM   #1
fitting a water tap
I have gas heating and wish to shut off my water supply to fit an outside water tap.
Do I close off water supply coming into the pressered gas boiler or do I just turn off the stop cock under my sink.
Will I have to drain my complete system
king2326 is offline   Reply With Quote
Old 08-29-2011, 05:09 AM   #2
DIY staff
Rewards Points: 7,174
Simply turn off the water coming into the house---no need to drain the boiler--
drain the house pipes by opening all sink faucets.
Move the hose bib and turn on the water again--then close all the sink faucets.
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
