Fitting Standpipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2012, 03:21 AM   #1
fitting standpipe
I havejust had a water supply fitted to the exterior of my cottage for renovation.It takes the form of a small manhole in which is a pipe with a plastic on/off valve , at the end of which is a threaded pipe which obviously is meant to connect to the interior water feed to the house.
Can anyone tell me what the size of this tread is and how i obtain a standpipe for the manhole so that i can get a water feed, or even something that i can screw on the feed pipe to attatch a hose.
den777 is offline   Reply With Quote
Old 01-22-2012, 06:48 AM   #2
DIY staff
Rewards Points: 7,174
We need a picture or a better description of the pipe---
You could just buy a 3/4" and 1" fitting and climb in and try them on for size--
Old 01-22-2012, 08:36 AM   #3
Rewards Points: 13,960
What would have been far better to have had installed would have been one of these on the supply side of the line.
http://www.northerntool.com/shop/too...-yard-hydrants
Those plastic ball valves always end up sticking. I stoped using them long ago and only use brass valves. More expencive but not going to break off the PVC when trying to shut it off.
Old 01-22-2012, 11:20 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I think hes talking about some sort of meter pit
plummen is offline   Reply With Quote
Old 01-22-2012, 12:31 PM   #5
standpipe
The 'man hole' is only about 18inches long by 12 inches wide. . In it , at about a foot down ( im pre decibel ) is a copper pipe about 3/4 inch diameter. And the end of the pipe, which strangely looks wider at the end, is a threaded bit, which looks about an inch and a quarter across to my untrained eye. The french must screw on something to the threaded end to serve as a standpipe. This is a new job carried just out by the Marie dept whilst i was not there . There are also a couple of other small manholes , also just fitted. One must be for the water meter, I have not opened them yet, I just want to find some way to fit a stand pipe first.
Old 01-22-2012, 01:33 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,... Sounds like 1" pipe thread....
Where on the planet are you,..??
Old 01-22-2012, 02:48 PM   #7
stand pipe
I am in England and the cottage is in Brittany, France
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
New standpipe, old house DirtyBrad Plumbing 0 07-22-2010 09:31 AM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
