Which Fitting Should I Use To Tap 3/4-cpvc To 1/2-pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2012, 07:48 PM   #1
Which fitting should I use to tap 3/4-cpvc to 1/2-pex
Below is a picture of what I have to work with. The lines on the left come from a 1/2 bath and the lines on the right are for a bar sink. I have purchased solvent cpvc to crimp pex connectors to go from cpvc to pex.
How should I attach the 2 pex cold and 2 pex hot lines to the 3/4 cpvc.
Two tee fittings on the hot and two on the cold cpvc line?
Put the 1/2 pexs together and just one tee fitting on the cold and one on hot?
Any other suggestions.
Which fitting should I use to tap 3/4-cpvc to 1/2-pex-img_2102re.jpg
casnj is offline   Reply With Quote
Old 03-23-2012, 08:16 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Use a 3/4 x 3/4 x 1/2 shark bite connector for each.
That would be the simplest
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-23-2012, 08:31 PM   #3
i wanted to stay away from sharkbites due to this being sealed off with drywall. Im alittle skeptical of sharkbites
Old 03-23-2012, 08:56 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 556
You don't see many of them but I have used CPVC x PEX adpter. Pretty straight forward.
Old 03-23-2012, 08:58 PM   #5
Rewards Points: 560
To each their own. But it wouldn't bother me to use them at all. Just did the same thing to a client's house last night.
I don't use them all the time but have used them for atleast 5 yrs with no problems
Simple and easy and they do work
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
CPVC lines with brass fitting mill1500 Plumbing 5 05-19-2011 09:43 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
