Old 01-15-2008, 07:11 AM   #1
First shower install, drain help please!
I just purchased this shower stall to finish my basement bathroom. I have never installed a shower or a drain.
http://www.maax.com/en/Products/Prod...2&Product=1651
Currently where the drain is in the concrete floor there is a grate top installed. In addition, when I position the shower stall over the drain and in place there is about a 2" gap between the floor and the bottom of the shower stall drain hole. Isnt the shower base supposed to sit flush against the concrete floor? How is a drain assembly installed to fill this gap? Is there a neck piece or something?
I tried searching online but couldnt find any good diagrams. The install manual just said to install drain per manufacturers specs.
Thanks for the help!
tigerbalm2424 is offline   Reply With Quote
Old 01-15-2008, 02:35 PM   #2
Was the drain for a prior shower or tub?
redline is offline   Reply With Quote
Old 01-15-2008, 02:50 PM   #3
The house was built with an unfinished basement. All the rough-in plumbing for the basement bathroom was there when I purchased it. This drain location lines up right where the shower was supposed to go per the plans, which is to say, right next to the toilet drain rough-in. How do plumbers usually cap off a shower drain if it wont be utilized right away?
Old 01-15-2008, 05:11 PM   #4
Send a message via AIM to Marlin
Sounds like what you have is a floor drain. Normally their would be a piece of pipe sticking up out of the cement.
What size pipe is the drain?
Can you take a picture of it?
Marlin is offline   Reply With Quote
Old 01-15-2008, 07:42 PM   #5
Arrow
I removed the gunk on top of the grate and then removed the grate. This is what i found:
So where do I go from here? Down the PVC is a bunch of dead flies it looks like. Also, there was no water in the pipe, what does that mean? This drain has been sealed since the house was new so Im guessing there has never been any water poured down it.
Old 01-16-2008, 06:23 AM   #6
That's something I haven't seen before. Are you adding a shower to an existing bathroom or did you just install the rest of the bathroom?
Old 01-16-2008, 06:44 AM   #7
I am tackling a completely unfinished basement. There has never been anything in this location except rough-in plumbing. The original plans show a bathroom in this location. The toilet drain and sink drain are all in position with no issues. This drain is in the correct location for the shower. All vents are there.
More On This Topic
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
You're thinking of replacing those old, worn out sliding shower doors with a new pivot-type of shower doors. There are lots of things to consider while selecting the right type of shower doors for your shower. Here's how to buy the right type of shower... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 10:20 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
shower drain nomoney Plumbing 4 05-19-2006 10:27 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
