Old 12-03-2012, 02:54 PM   #1
First post, and how/if I should install a slop sink in the garage?
This past Friday we discovered that our septic tank had a drainage problem and had reached it's limits, backing up into the washing machine drain in the basement. That drain is the only drain in the basement, the lowest in the house. Unfortunately, I had just remodeling that side of the basement, new walls, new floors, the works. The flooring is shot, walls are still good though (according to the pros at ServPro). We got the septic tank pumped and fixed the drainage lines this weekend.
My question is this: I don't want it to happen again, and if it does, I don't want overflow to go anywhere near the remodeled side of the basement. The other half is the garage. My idea is to put in a slop sink, a good 5-6' away from the dividing wall between the garage/finished basement. That will be a "sacrificial" drain of sorts, the first place a backup will show, semi-safely away from the remodeling work. The problem I see is the height of the main septic line and the washing machine drain. The drain of the sink would need to be higher the height of the main septic line, but lower than the washer drain, correct?
I'm linking to a picture of the plumbing there (with the backside section of a wall torn out to check for water damage). The washer drain is on the far right, the pinkish light is coming from the other side of the wall and is the inlet of the drain.
One idea floating in my head is to raise the height of the washing machine drain and run the sink plumbing off that lowest line coming out of the main septic line.
To visualise my plan:
Is this a good idea? Will it work? Any better ideas? I really just want to protect my hard work on the other side of the wall.
jrbryner is offline   Reply With Quote
Old 12-03-2012, 03:29 PM   #2
Your location will likely be too close to your electrical load center.
sgip2000 is offline   Reply With Quote
Old 12-03-2012, 04:32 PM   #3
There doesn't seem to be a trap on the existing laundry box?
Ishmael is offline   Reply With Quote
Old 12-03-2012, 04:41 PM   #4
call me E
TheEplumber's Avatar
You could just install a backwater valve on the laundry line. then there would be no future flooding.
Old 12-03-2012, 06:37 PM   #5
Ther is a trap there, it's hidden behind the water heater.
Old 12-03-2012, 06:39 PM   #6
Ah. Didn't think of that. If I just install it further down the wall, would that suffice?
Old 12-03-2012, 06:40 PM   #7
The problem I've thought there, is that then it will eventually back up to the upstairs (if it gets that catastrophic), making the problem worse.
Old 12-03-2012, 06:40 PM   #8
That would likely be okay. Hopefully one of the pro's will chime in with the minimum distance.
Old 12-05-2012, 11:28 AM   #9
From research I've done around, it seems like the minimum distance is 30"-36". I'll go with 36" to be safe. But it's measured in a square containing the box. So, in the picture above, it'd be 36" from the right side of the electrical box. Seems strange, but that's what I found. There's a window behind that curtain there, I'll just put it to the left of the window.
