-   -   First post, and how/if I should install a slop sink in the garage? (http://www.diychatroom.com/f7/first-post-how-if-i-should-install-slop-sink-garage-165491/)
jrbryner 12-03-2012 01:54 PM
This past Friday we discovered that our septic tank had a drainage problem and had reached it's limits, backing up into the washing machine drain in the basement. That drain is the only drain in the basement, the lowest in the house. Unfortunately, I had just remodeling that side of the basement, new walls, new floors, the works. The flooring is shot, walls are still good though (according to the pros at ServPro). We got the septic tank pumped and fixed the drainage lines this weekend.
My question is this: I don't want it to happen again, and if it does, I don't want overflow to go anywhere near the remodeled side of the basement. The other half is the garage. My idea is to put in a slop sink, a good 5-6' away from the dividing wall between the garage/finished basement. That will be a "sacrificial" drain of sorts, the first place a backup will show, semi-safely away from the remodeling work. The problem I see is the height of the main septic line and the washing machine drain. The drain of the sink would need to be higher the height of the main septic line, but lower than the washer drain, correct?
I'm linking to a picture of the plumbing there (with the backside section of a wall torn out to check for water damage). The washer drain is on the far right, the pinkish light is coming from the other side of the wall and is the inlet of the drain.
http://f.cl.ly/items/2l1N0k1N3A1w2x1S3U3M/IMG_1480.jpg
One idea floating in my head is to raise the height of the washing machine drain and run the sink plumbing off that lowest line coming out of the main septic line.
To visualise my plan:
http://f.cl.ly/items/2N1E3G2c1b1a1s1..._1480maybe.png
Is this a good idea? Will it work? Any better ideas? I really just want to protect my hard work on the other side of the wall.
sgip2000 12-03-2012 02:29 PM
Your location will likely be too close to your electrical load center.
Ishmael 12-03-2012 03:32 PM
There doesn't seem to be a trap on the existing laundry box?
TheEplumber 12-03-2012 03:41 PM
199 Attachment(s)
You could just install a backwater valve on the laundry line. then there would be no future flooding.
jrbryner 12-03-2012 05:37 PM
Ther is a trap there, it's hidden behind the water heater.
jrbryner 12-03-2012 05:39 PM
Ah. Didn't think of that. If I just install it further down the wall, would that suffice?
jrbryner 12-03-2012 05:40 PM
The problem I've thought there, is that then it will eventually back up to the upstairs (if it gets that catastrophic), making the problem worse.
sgip2000 12-03-2012 05:40 PM
That would likely be okay. Hopefully one of the pro's will chime in with the minimum distance.
jrbryner 12-05-2012 10:28 AM
From research I've done around, it seems like the minimum distance is 30"-36". I'll go with 36" to be safe. But it's measured in a square containing the box. So, in the picture above, it'd be 36" from the right side of the electrical box. Seems strange, but that's what I found. There's a window behind that curtain there, I'll just put it to the left of the window.
