-   -   First Floor Laundry Room Floor Drain install? (http://www.diychatroom.com/f7/first-floor-laundry-room-floor-drain-install-120665/)
hammerlane 10-20-2011 09:23 AM
5 Attachment(s)
Want to put floor drain in first floor laundry room in case of you know what. Have unfinished basement under laundry area with one of the drain stacks close by. In the following pictures A thru G I've numbered runs for reference only when looking at different views.
#1 is 3" elbow to a toilet,
#2 is the 3" run that takes toilet and 1st floor laundry room sink and washing machine discharge to stack,
#3 is a vent,
#4 is 1.5" from 1st floor laundry room sink and washing machine discharge.
If I plumb the laundry room floor drain into the stack I know I'll need a p-trap and then have to be sure water remains in the trap to stop sewer gas.
So my thought is (see photos F and G) to utilize a 3" floor drain in the basement being used only for condensate discharge from furnace & A/C.
I was thinking to install the 2" laundry room floor drain somewhere in the marked area, run PVC along wall and terminate it in the 3" existing floor drain just in case laundry room ever floods.
Is this a bush-league remedy or would it be easy enough to plumb the drain into the stack?
Thoughts and comments welcomed.
hammerlane 10-20-2011 09:24 AM
2 Attachment(s)
Two additional pictures
Alan 10-20-2011 09:36 AM
Are you planning on connecting that directly to the drain? I'm not sure you can run a floor drain like that as an indirect waste, and you probably can't use the p-trap from that 3" to serve something located on the 2nd floor.
For one thing, it would make it a heck of a lot easier to tie it into one of those other lines there and put a p-trap and a trap primer on it.
:eek:
hammerlane 10-20-2011 10:18 AM
:eek:
My thought was to just elbow the 2 inch(depicted in green in photo G) right into the current basement floor drain since this 2 inch would only direct water in the emergency situation where the first floor laundry room floods. A good name for this would be "an indirect waste" as you call it.
Alanyou say,"and you probably can't use the p-trap from that 3" to serve something located on the 2nd floor".
What p-trap are you referring to? Hopefully not the condensate trap in photo G. Even though the green lines look like they terminate there that was not my intention. Photo G only shows a continuation of the 2" I suggest running along the wall in photo F.
Also the laundry room floor drain I want to put in will be on the 1st floor not 2nd floor.
Alan 10-20-2011 08:54 PM
I'm referring to the 3" p-trap underneath the floor drain in the slab.
:eek:
What I meant by 2nd floor was the next floor up. I don't know how many stories are in your home.
I'm pretty sure that what you're wanting to do aint kosher at all, but i'll let someone in your general area chime in.
TheEplumber 10-20-2011 10:29 PM
199 Attachment(s)
I gotta agree with Allen.
It will be an easy and cleaner job if you plumb it as a normal floor drain. Water for a primer can come from your lav. Waste can tie into your stack or the 3". Pretty much outa site-outa mind. :) No indirect pipe to trip over
Alan 10-20-2011 10:35 PM
What's easier is that you probably don't even need a vent for it. In my area if you're within 5' of a vented line, you don't need an individual vent for the floor drain.
Agree with eplumber. Tie that trap primer in inside of the cabinet and run the discharge pipe down through the cabinet base and over to your floor drain's primer adapter.
If you want it clean looking you could open up a wall, but I don't really see a reason to do so as long as you tuck it into the corner of your cabinet where it's out of the way.
TheEplumber 10-20-2011 10:40 PM
199 Attachment(s)
Great minds think alike :thumbup1:
hammerlane 10-21-2011 04:36 AM
Ok for the p-trap for the current basement floor drain. I thought you were seeing a p-trap somewhere near that stack. And I know what I want to do is not kosher but is simpler than cutting into stack and having to use a trap primer. And seeing that the 2" I was proposing to run from would only see water running thru it in the emergency situation that the first floor laundry flooded, the last thing I would be concerned with is whether it was kosher. So long as it directed water from laundry room out.
I knew I woulnt find someone to agree with my proposed solution but do appreciate your guys' commments. Right is right and wrong is wrong.
I'll take all
Alan 10-21-2011 09:12 AM
I don't really think so. . . . :eek:
