First Experience With Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2014, 07:36 AM   #1
Rewards Points: 3,130
First experience with Pex
So, had to replace a valve in my RV. Being relatively new, the rig is plumbed with Pex. First headache: find a replacement valve. Took a 40-mile drive to the nearest RV place for that as Home Depot doesn't seem to have them.
Second headache: Don't own a crimp tool. Was told hose clamps won't work. Ended up buying a pocket tool ($25.00) for making two crimps. Yet another tool that's good for absolutely nothing else, and a PITA to use as well.
An expensive fix to be sure, but at least I have hot water again. Say what you will about CPVC, but I'll take it any day.
Old 04-04-2014, 07:46 AM   #2
Rewards Points: 14,294
Could have just bought a Shark Bite valve and needed no tools.
Pex is a perfect choice to plumb RV's.
It's not going to split the first time it freezes like CPVC would.
rjniles (04-04-2014)
Old 04-04-2014, 08:56 AM   #3
Rewards Points: 30
Should have bought Sharkbite brand valve. Home Depot specializes in them so I know they had it in stock. You can return the "pocket tool" for full credit if you bought it at Home Depot.
IMHO brittle CPVC would be among the WORST choices for use in an RV.
SHR Plumber is offline   Reply With Quote
The Following User Says Thank You to SHR Plumber For This Useful Post:
Old 04-04-2014, 01:10 PM   #4
I did buy a Sharkbite valve - that's what the RV store had. If HD carries them, they must've been out of stock. As for the tool, whether they'd take it or not, I wouldn't feel right returning a used item for a refund.
Old 04-04-2014, 05:46 PM   #5
Rewards Points: 2,104
Make sure you put the stiffeners in the pex both ends prior to using the sharkbyte.
Old 04-04-2014, 05:51 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 904
If you use the stainless steel cinch rings instead of crimp rings, one tool will fit 3 sizes and cost a lot less than 3 crimp tools.
Old 04-04-2014, 08:57 PM   #7
The pocket tool I bought fits three sizes of crimp rings.
Old 04-04-2014, 09:32 PM   #8
Lord of Slums
Rewards Points: 1,974
My rv still has heater hose I used for my water line repair.
mj12 is offline   Reply With Quote
Old 04-04-2014, 10:12 PM   #9
Rewards Points: 30
I agree with your earlier post, those things are a real PIA to use. I own one and use it occasionally when the work space is too limited to fit my normal crimp ring tool. Hate it but it does a good job.
Old 04-04-2014, 10:15 PM   #10
Rewards Points: 30
Good point Ghostmaker. Many knock-off brands package the inserts loose or separately. Sharkbite fittings are sold with the inserts already installed and you actually should remove them prior to using them on copper, yet most users do not. So, no issue with making sure to insert the stiffeners.
Old 04-05-2014, 06:09 AM   #11
My valve came with no stiffeners. Since the Pex slides over the "barbed" ends of the valve, why would I need them?
Old 04-05-2014, 07:48 AM   #12
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,708
Ayuh,.... If yer valve has barbs, 'n ya used crimp rings,...
It Ain't a Sharkbite fittin',....
Bondo is online now   Reply With Quote
Old 04-05-2014, 08:00 AM   #13
Rewards Points: 2,028
Shark bite ( brand ) with barbs, yes. How do you think the plumbing industry got so screwed up over the years.
Old 04-05-2014, 11:34 AM   #14
Bondo's Avatar
Ayuh,.... Yer No doubt Right,...
I ain't a plumber, I'm just Handy,....
I equate "Sharkbite" with "Push-lock" fittin's,...
Like the Xerox copier,...
As a DIYer, whats been your experience dealing with inspectors? JustinNY General DIY Discussions 16 11-10-2013 11:35 AM
Bamboo flooring anyone with experience with Costco Strand woven or others ctaylor619 Flooring 1 09-08-2013 12:55 AM
Experience with HVACmegastore frank1492 HVAC 0 09-10-2010 12:25 PM
Any experience with Roxul? Jim McClain Remodeling 5 02-23-2010 03:10 PM
