Old 09-10-2011, 09:46 PM   #1
First attempt at plumbing fumble
Hi all,
I attempted today to replace two stop valves underneath my kitchen sink. But once completed there was no water pressure from my kitchen sink anymore.
Here are the steps I preformed. Hopefully someone will be able to tell me what I did wrong.
-Once I turned off the water I disconnected the supply line to the faucet.
-I cut the copper pipe behind the old valve. Then I brushed off the end of the exposed pipe.
-I placed the compression nut on the exposed pipe then slipped the ferrule in.
-I applied ptfe thread seal tape to all the threads. ~1 layer, some overlap on the end.
-Then I screwed the valve into the nut and the supply line into the valve and into the sink (replaced the line as well).
Then I turned the water back on, opened the valves and turned on the sink. All I get is a trickle.
The valves are compression in and compression out if that makes a difference.
My question is what did I do wrong? Did I tighten them too tight? I tried loosening some but still just a trickle.
Thanks.
foolio2000 is offline   Reply With Quote
Old 09-10-2011, 10:01 PM   #2
Persona Non Grata
VIPlumber's Avatar
Pipe dope is not needed on compression fittings. Most likely it's fouling/blocking the valve. You'll have to take the valves off and clean them.
VIPlumber is offline   Reply With Quote
Old 09-10-2011, 11:18 PM   #3
call me E
TheEplumber's Avatar
Try cleaning the faucet aerator too
The Following User Says Thank You to TheEplumber For This Useful Post:
josall (09-11-2011)
Old 09-11-2011, 03:30 PM   #4
clean the aerator first, if that doesn't work, then take the valves that you put on and make sure that there is no blockage there,
http://www.hawthornesplumbing.com
pdhawthorne is offline   Reply With Quote
Old 09-21-2011, 09:27 PM   #5
Turns out it was indeed the faucet aerator. Thanks everyone for your help.
Old 09-22-2011, 12:52 AM   #6
Persona Non Grata
VIPlumber's Avatar
So what was gumming up the aerator?
Old 09-22-2011, 08:08 AM   #7
It was probably the cause to replace the vales in the first place. OP thought it was the valves.
COLDIRON is offline   Reply With Quote
1st attempt at plumbing: Need help malt0se Plumbing 2 03-28-2011 10:38 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
How to find plumbing distributors for plumbing invention? Timster Plumbing 7 05-20-2009 02:53 AM
