Finishing Upstairs Bonus Room - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2007, 01:00 PM   #1
Hello...
I am finishing the upstairs bonus room (which was just framing) and am planning on adding a new bathroom. I will have a toilet and a pedestal type sink, no shower. I have severala questions:
1. New toilet and sink drain - is my best bet to come down through the second floor and first floor to my crawl space and tie into my existing sanitary drain?
2. Can these two drains run together? and can these be vented together?
3. Regarding the new vent, what size should the vent be for the toilet and sink? The toilet floor drain should be 3" correct? The sink drain should be 1 1/2" or 2"...?
Last question - what is the easiest way to run new hot and cold water to the upstairs? Can I tap into the hot and cold sides of my water heater, right at the WH?
Thanks so much for any comments and/or suggestions...
Scott
luner99 is offline   Reply With Quote
Old 02-08-2007, 12:59 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
1. That is the way I would do it, without being there and seeing the layout.
2. Yes
3. Toilet will be 3" and sink can be 1-1/2 but we always run sinks at 2", vents are min here 2" for toilet and 1-1/2" for sink.
4. Yes tap in at water heater area and run to next floor from there.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-26-2007, 01:28 PM   #3
Tapping new water lines for new bathroom
I currently have all copper installed in my house. I am finishing the upstairs and I am adding a half bath (toilet and sink). The water heater is located in the garage.
My question is this, can I tap off of the hot and cold lines that are at the top of the water heater and run up the wall and through the ceiling to my upstairs? Can I do this with a tee of some sort that will allow me to go from copper to PEX?
Thanks...
Scott
Old 02-26-2007, 01:39 PM   #4
Thanks Ron...
Is there a tee type connector that I can cut my existing copper lines and insert this tee so that I can run PEX off of it? Whats the easiest way to go from copper to PEX?
Old 02-26-2007, 02:32 PM   #5
How close is the nearest bathroom?
redline is offline   Reply With Quote
Old 02-26-2007, 04:34 PM   #6
Journeyman Plumber
Use a fitting called a Sharkbite, get a tee, this is the no brainer fittiing, slips onto the copper and you can take off with pex from it.
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-22-2007 12:12 AM
Plumbing questions - finishing upstairs bonus room luner99 Building & Construction 1 02-07-2007 08:12 PM
Insulating a bonus room dencrimi Building & Construction 3 01-06-2007 01:53 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 12:51 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
