Finishing A Basement Bath Vent? Pump-up Toilet Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2010, 07:43 PM   #1
Finishing a basement bath Vent? Pump-up toilet connection
HI All,
Admittedly, I am a first timer to the plumbing game so excuse my ignorance.
I am having my basement finished and am adding a half bath. I live in North Attleboro, MA and am on septic. I will be using a Saniplus pump-up toilet kit. I have plenty of room behind the wall where the sink drain and toilet pump-unit will reside so running the drains and various plumbing shouldn't be a problem.
I have two questions:
1. Venting-I have found the future vent in my basement so I plan to use that. The question is, I have to vent the sink and the pump up/toilet so do I need to run two seperate pipes to the future vent or can I Y them together at some point? If I follow the same grade as the 4 inch waste line (1/4 inch per foot) going to the septic pump will I be conforming to code? I was concerned about how many linear feet I will be running the vent but I found another posting on this website (from a MA plumber) advising that up to 150 feet is allowed.
2. The installation guide for the toilet I am using speaks at length about making all vertical runs of the pump-up discharge pipe precede any horizontal runs. The waste pipe I am going to T into is directly above the pump up unit so I plan to run the pipe straight up from the unit (about 8 feet) and then horizontally (about two feet) before I connect to the waste line. When I connect to the waste line, I plan to connect it paralell to the basement floor. Am I missing any obvious issues/code violations there?
Thanks in advance for any help you can offer,
Paul
heenanp is offline   Reply With Quote
Tags
basement , plumbing , pump , toilet , vent
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Need unbiased help on finishing basement - Dry wall or panel system? mmr1234 Building & Construction 6 08-29-2009 11:30 AM
Basement Flooding / Sump Pump -- Should I get a generator added to my home. DIY_Help General DIY Discussions 9 02-20-2009 06:36 PM
New toilet in basement altadata Plumbing 1 02-10-2009 12:53 PM
