Finish Trim To Cap Off Unused Water Supply Outlet - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2011, 12:07 AM   #1
finish trim to cap off unused water supply outlet
i have a water outlet that I no longer want to use. it is just a rough-in copper pipe sticking out with a copper cap. And is in a very visible location. Is there a trim that can cap it off with a more finished look than a copper cap?
acerunner is offline   Reply With Quote
Old 07-07-2011, 07:53 AM   #2
Plumb or Die!
Nothing that would look good. You could probably get away with cutting a 3" round hole and use mini copper cutters and a sharkbite cap. Then patch the hole.
plumber666 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 07:01 PM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
