Finish Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2012, 01:08 AM   #1
Question
Finish plumbing
I have to install a shower head in a finished bathroom (tiled) however at the shower head all that is showing is a capped copper pipe. Do I need to remove any tile to see if the proper fittings have been installed or can I put another fitting on the copper to attach to neck for the shower head? Thanks for any help. I have to finish this within the next two weeks.
KDiaz is offline   Reply With Quote
Old 07-27-2012, 01:13 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
try grabbing the very end of the copper where the cap is and trying to unscrew it. There should be one of these in the wall : http://www.plumbinghelp.ca/images/Drop%20ear%2090.jpg
You should also be able to see (through the hole) the hex on the other end of the copper sticking out. We usually use trashed brass nipples or galvanized for that purpose so that the tile won't cover up too much of the opening that we need for the shower arm to come out.
If they've tiled up tightly to the copper, you may have trouble getting it out.
P.S. : Are you sure it's copper, and not a brass nipple?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
jaydevries (07-27-2012)
Old 07-27-2012, 05:34 PM   #3
Rewards Points: 582
that should come out ..that is a test nipple used to check for leaks while setting tile....
new basement plumbing karenfazeng Plumbing 1 07-02-2012 12:35 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Under-slab or In-slab plumbing? CplDevilDog Concrete, Stone & Masonry 1 06-13-2012 07:43 AM
Shower Plumbing Set Too Far Back?? plumb_confused Plumbing 2 06-01-2012 08:23 PM
Eggshell Finish Confusion fjmartinez Painting 5 05-24-2012 09:34 AM
