Finding A Crack In A Fiberglass Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2012, 03:16 PM   #1
Finding a Crack in a Fiberglass Bathtub
Hello everyone. New to the forum, thanks in advance for any guidance.
My ceiling has been leaking under my one piece shower/tub (fiberglass) when my little son takes a bath.
I had the plumber in today. Ive been told that I have a crack in the tub.
He changed out the drain and any gaskets and cut a hole in the ceiling. He is very confident (as am i ) that its not the plumbing.
The water, now that the ceiling is open, is coming from the middle of the tube somewhere, pooling on the floorboard, and flowing down to the ceiling near wear the drain was cut out.
We went upstairs and we cannot see any crack in the tub. I stood in it as he looked and we still couldnt locate it.
Is there a method to finding a crack...kinda like a a hole in a tire...that i dont know about it.
Thanks... Im really stuck here.
Max
maxweenus is offline   Reply With Quote
Old 09-04-2012, 04:32 PM   #2
Rewards Points: 13,752
Add red food coloring to the water so it shows up better.
Are you 100% sure it's not leaking over where the plumbing itsor behind the covers where the knobs are.
Also look along the floor where the tub sits for missing caulking.
Old 09-04-2012, 08:45 PM   #3
Rewards Points: 352
does it leak when anybody else takes a bath or just when your son bathes?
plumberinlaw is offline   Reply With Quote
Old 09-04-2012, 10:07 PM   #4
now that the ceiling is open I can see it leaks with baths or showers, not just when he's in there. it's pooling on the subfloor under the tub then leaking down the cutout to the ceiling.
from process of elimination, a crack in the tub seems like an obvious culprit right?
Old 09-04-2012, 10:35 PM   #5
let everything dry and then fill the tub with water and see where the water comes from.
Old 09-04-2012, 10:38 PM   #6
thanks Danny but I can't see under the tub. no access. cant get my head up there. I'd need some sort of camera or scope.
Old 09-05-2012, 07:30 AM   #7
Rewards Points: 352
Harbor freight has a small camera with about 3' of flexible lead between the camera and hand held monitor
Tags
crack , shower , tub
fiberglass mat and resin flat roof 5 year report bobinphx Roofing/Siding 3 07-06-2012 05:25 PM
Drywall Crack Diagnosis lkstaack Drywall & Plaster 7 03-11-2012 09:45 AM
Horizontal Wall Crack gerardswork General DIY Discussions 8 01-25-2012 06:51 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
Crack in Concrete Slab under the Front Door diy4life Building & Construction 4 04-08-2009 09:11 AM
