Finally Finished My Heating System - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2011, 11:00 AM   #16
Rewards Points: 16
Hi Gnfanatic, very nice job. I am planning to do something like that too. I have a few rooms to heat. Can you provide some details on your system ? I think you are using hot water to feed some heat radiators , is that right ? what heating box do you use to distribute the hot water? Does the heating box comes with an internal pump or do you need an external pump to distribute the hot water? Do you use a thermostat for the entire house or do you have different zones which can be controlled spearately?
DIY_user is offline   Reply With Quote
Old 01-16-2011, 11:44 PM   #17
Picky Plumber
It looks like he has 2 zones (pumps) there.
Plumber26 is offline   Reply With Quote
Old 01-17-2011, 08:47 AM   #18
Rewards Points: 99
4 zones , 8 circuits. 1 of the pumps is for the indirect. diy-user i will PM you some info on the design
Gnfanatic is offline   Reply With Quote
Old 01-17-2011, 07:12 PM   #19
Rewards Points: 16
Thanks a lot Gnfanatic, looking forward to see your PM.
uneven heating from hot water system JLAP Plumbing 9 12-21-2009 12:14 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 05:12 PM
Thermostat for new heating system pb2 HVAC 0 11-30-2009 11:41 AM
Changing my heating system, need advice sethfc HVAC 4 08-10-2009 09:46 AM
Debugging Hot Water Heating System when on Standby Power hwitten Electrical 4 12-15-2006 08:47 PM
