Old 01-10-2011, 10:22 PM   #1
Finally finished my heating system
Hey guys, first time building a heating system (took me about 80 hours total). Need to run some pex and get the plumber over to install the gas line. Cant wait to finally have heat in my house What ya guys think? Be easy on me
Finally finished my heating system-dsc_1259-medium-.jpg   Finally finished my heating system-dsc_1263-large-.jpg
Gnfanatic is offline   Reply With Quote
Old 01-10-2011, 10:44 PM   #2
Experienced
Jackofall1's Avatar
Very nice lookin job, your hired!
Old 01-10-2011, 10:46 PM   #3
It certainly looks neat and orderly. What kind of a boilder is that? It must be much lighter that my Weil-McLean oil fired boiler if it can mount on the wall like that. I don't know how those poor guys got it down the basement steps and in place without hurting their backs.
Jim F is offline   Reply With Quote
Old 01-10-2011, 10:47 PM   #4
thanks guys. its a Triangle Tube boiler, made in Belgium. I mounted it myself, I believe it weighs roughly 100 lbs give or take. Its 96% efficient.
Old 01-10-2011, 11:31 PM   #5
looks pretty damn good, a lot better than most of em i see. the only things i don't like about it is the t&p drain is awfully high and the expansion tanks could use some strapping to secure them on the wall. i'm not a fan of them being supported by the piping. other than that (little stuff ) it looks nice enough to take home to mom
the_man is offline   Reply With Quote
Old 01-10-2011, 11:43 PM   #6
call me E
TheEplumber's Avatar
Looks good! Whats the blue and white box on the shelf?
Old 01-11-2011, 12:01 AM   #7
The potable tank is strapped from the floor joist above . I need to figure out how to secure the system tank better. I mounted the T&P exactly the way the manufacturer stated and showed in the diagram. I suppose you are talking about the one on the boiler???
Old 01-11-2011, 12:02 AM   #8
That little guy will call 3 telephone numbers if it senses a pressure drop or temp drop. I can also call the box to get info from it. Going to install a battery backup to it as well.
Old 01-11-2011, 01:00 AM   #9
call me E
Sweet ,My guess was some sort of router. I was close
Old 01-11-2011, 07:38 AM   #10
Man, that is one pretty system, I hope it works as good as it looks. You do outstanding work, I am curious what do you do for a living ? No need to answer if you don't feel comfortable.
COLDIRON is offline   Reply With Quote
Old 01-11-2011, 09:21 AM   #11
I was in the IT field for 10 years now I work full time at my families pizzeria. I am a pizza maker now, haha
Old 01-11-2011, 10:54 AM   #12
Picky Plumber
The T&P needs to terminate at within 6'' of the floor. Picture it blowing off w/ 180 degree water coming out of it and someone happens to be in that area admiring the beautiful work you did. Instant skin graft! Really would suggest it be done. It's code.
Plumber26 is offline   Reply With Quote
Old 01-11-2011, 11:04 AM   #13
I have gas!
Clutchcargo's Avatar
Nice job, it looks better than pro.
One thing though, are those outlets sharing the circuit with the heating system?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-11-2011, 11:10 AM   #14
Thank you sir, I did not know that!! I will fix it this week. See anything else?? I did check the pressure of the tanks as well, I pressure tested the system to 40 psi., out of the 148 joints I soldered, 4 leaked. I took the 4 apart, cleaned and resoldered. no more leaks. I also flushed the system.
Old 01-11-2011, 11:12 AM   #15
hey, yes they are. BUT they are only there for emergency purposes. They will probably never be used. No one will be connecting a saw to it I ran 12-3 MC BX to the unit with a 20 amp breaker. I know its overkill but I feel better doing it. thanks for the compliment
uneven heating from hot water system JLAP Plumbing 9 12-21-2009 01:14 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 06:12 PM
Thermostat for new heating system pb2 HVAC 0 11-30-2009 12:41 PM
Changing my heating system, need advice sethfc HVAC 4 08-10-2009 10:46 AM
Debugging Hot Water Heating System when on Standby Power hwitten Electrical 4 12-15-2006 09:47 PM
