Final Stages Of Hooking Up Dishwasher Need Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2011, 03:26 PM   #1
K.M.G's Avatar
Rewards Points: 105
Final stages of Hooking up Dishwasher need advice
Hi
The Electrician Finally came and installed my outlet and the plug on the diswasher
I need to drill into the Kitchen sink base cabinet for the water supply and dishwasher drain hose now.
How many holes do I drill and where?? High or low
Can I drill one big hole and feed everything through that or do I drill a hole at the bottom for the water supply and a hole very high for the dishwasher drain hose.
Also if it's best to only drill one big hole,do I run any risk of the plastic melting with the stainless braided line.
I've never used owned a dishwasher so this is very new and wasn't sure,as they say water doesn't flow up hill but maybe that rule changes with dishwashers and drain hoses.
Thank-you for your time
My Bathroom Project done
http://www.diychatroom.com/f49/bathroom-done-70572/
Thankyou everybody for your help!!!
K.M.G is offline   Reply With Quote
Old 01-13-2011, 03:43 PM   #2
Experienced
Jackofall1's Avatar
You can drill 1 hole low on the base cabinet to feed both HW and drain from/to DW.
Old 01-13-2011, 04:19 PM   #3
Rewards Points: 256
Drill 2 holes. One smaller low for supply, one bigger as high as you can for the drain. In your area code might even require a vacuum breaker next to where the sprayer goes. I personally don't use or like them.
You could run the supply line up high (one hole) but that would take a longer hose.
michaelcherr is offline   Reply With Quote
Old 01-13-2011, 04:32 PM   #4
Experienced
Jackofall1's Avatar
So there you have it, 1 or 2 high or low, 1 high, 1 low, both lines high, both lines low.
Its really your preference. I chose low because that is where the connections are on the DW. Michaelcherr has a good point with the vacuum breaker, if you are interested in following code, I like Michaelcherr don't particulary like them.
Old 01-13-2011, 04:47 PM   #5
I would drill 3 holes!
But seriously, the instructions for the DW usually show where the manufacturer thinks they should be. When I can, I drill one big hole for both pipes.
broox is offline   Reply With Quote
Old 01-13-2011, 05:54 PM   #6
Rewards Points: 1,214
1 Big Hole Low. 2 or 21/2 inch need plenty of room when jockeying Dish Washer into place.
COLDIRON is offline   Reply With Quote
Old 01-13-2011, 07:09 PM   #7
Residential Contractor
This is correct.
rselectric1 is offline   Reply With Quote
Old 01-13-2011, 07:10 PM   #8
my code requires an airgap, or since nobody likes them a loop in the drain line hose up to the underside of the countertop. b/c of this, i drill my drain at the very top, and a small hole for my water at the bottom.
the_man is offline   Reply With Quote
Old 01-14-2011, 07:35 AM   #9
All My Utilities go through one big hole in the bottom as far back on the side as they can go then when I am installing or reinstalling after service as I am slowly pushing it back into place I am taking the slack out by pulling the Utilities through little at a time until the machine is ail the way in place.
All connections are made under the sink including air gap. All Utilities are flexible, IE: electric on a cord that plugs into 20 amp outlet under sink, stainless steel flex for water supply and corrugated plastic drain hose to air gap then to y drain under disposal.
It all works out good for service and repair if needed and eases installation.
Old 01-14-2011, 08:01 AM   #10
For you're hot supply line just use common sence with drilling the hole, But for your dishwashers drain line, it must be as high as possiable, if its not your going to having dirty water siphioning back into your dishwasher.
Bigd3129 is offline   Reply With Quote
Old 01-14-2011, 09:07 AM   #11
If you read my post again you will see where I reference the air gap under the sink cabinet. REREAD.
Old 01-14-2011, 09:13 AM   #12
but you don't have the airgap itself under the sink right?
Old 01-14-2011, 09:27 AM   #13
Let me explain air gap as it pertains to me.
Discharge line comes through the hole down low that goes up to the sink rear where it's attached to a chrome air gap fitting that is screwed into the additional hole next to the faucets- it then goes from there to the drain stub under the dishwasher.
Another way to do this is to bring the drain hose through the cabinet hole and then take it all the way up as far as you can up under the sink lip secure it there then bring it back down to the drain stub.
Both ways prevent siphoning back .
The Following User Says Thank You to COLDIRON For This Useful Post:
the_man (01-14-2011)
Old 01-14-2011, 09:30 AM   #14
ok... sounded like you were leaving the airgap loose in the cabinet space. obviously a big no no
Old 01-14-2011, 12:08 PM   #15
Rewards Points: 3,130
Not germane to your question, but I'm curious: is it local code for a dishwasher to have a power cord with a plug? I've owned 10 houses in several places over the years and have never seen that. Disposal maybe, but not a dishwasher. Why would you ever need to unplug it?
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 10:59 PM
dishwasher drain hose onelson Plumbing 4 03-16-2010 10:55 PM
the dishwasher won't drain anymore (due to broken glass?) diy'er on LI Appliances 7 12-14-2009 11:38 AM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 05:28 PM
Need Advice for Final Inspection Bobby General DIY Discussions 5 09-22-2006 03:50 PM
