-   -   Filtration for a well (http://www.diychatroom.com/f7/filtration-well-18058/)
wla6518 03-05-2008 04:59 PM
I am looking to put a softener and filter on a well water system.
I am set on the Fleck 7000 for the softener, but lost on what type of filtration.
We have a problem with a sulfur odor in the water. Can yall help out?
USP45 03-05-2008 05:41 PM
get a whole house filter with a charcoal filter insert. Works great. Can be installed at the well, or in the basement
doggofast 03-06-2008 06:41 PM
It depends on what you want to filter out of the water as to what type of filter you install. It sounds as if your biggest issue is the sulfur smell. If it is the typical rotten egg smell that many folks complain about, you should know that there are several different causes for that. The first is the anode rod in the water heater. Often times because of the chemical nature of some well water, the anode rod will produce this odor. Obviously, you will notice this in the hot water most of the time. The second cause of the rotten egg smell is bacteria build up in the well itself. Disinfecting and flushing the well with bleach can take care of the problem in most cases. The third possibility is that the sulfur smell can be leaching from the formation the groundwater is drawn from. In this case, the filter mentioned or something similar may be a good option.
wla6518 03-19-2008 09:03 AM
It is generally only when the hot water is on. What can I do about this?
If I just replace the Anodes, will it just return again? If so, is there a way to prevent this?
doggofast 03-19-2008 04:21 PM
I think this link will help
http://homerepair.about.com/od/plumb...lsht_hwh_5.htm
