Filter Fabric For Sump Pump? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2011, 09:05 AM   #1
filter fabric for sump pump?
OK- moving forward- I got the sump pit dug out as deep as I can get it (about 18")- The new plastic basin is 24"- I will most likely cut the bottom off the basin and lay it in a bed of gravel and then a patio block. Do i still need to put filter fabric to prevent silt? (there was not one there b4)- The soil is very rocky/slate (I live in central NJ). Also the new bin is not perforated so is there a formula for how many holes? The old metal pit seems to have a number of 1/4" holes in it (problem is-half of that old one disintegrated so I can't really tell)- thanks!
mongo1968 is offline   Reply With Quote
Old 12-01-2011, 10:11 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,074
Ayuh,... If yer gonna cut the bottom of the bucket out, there's No need to be drillin' holes in what's left...
And,...
If silt wasn't a problem before,...
I donno why it would be now...
I'd skip the filter fabric, 'n the gravel, 'n just put yer patio block in the bottom, with the pump sittin' on it...
Old 12-01-2011, 10:15 AM   #3
Rewards Points: 13,458
I never would have cut out the bottom, now there will be no strength to stop the side load.
I drill 3/8 holes all over the outside and the bottom wrap screen cloth around the outside to stop the silt from coming in and just set the pump in the pit.
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 05:49 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
