Filter Before Or After The Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-06-2009, 06:07 PM   #1
Filter before or after the tank?
I am in the process of changing out my bladder tank and replacing the whole house filter assembly with a larger unit and am wondering if before the bladder tank or after is the best place for the filter assembly. The current setup is after the tank. Thank You.
Plumbvoltage is offline   Reply With Quote
Old 08-07-2009, 09:56 AM   #2
Water quality'n pump guy
You never want to install anything that can block up between a pump and its pressure switch; so after the tank but, disposable cartridge filters are not a good choice for point of entry (POE) filtration.
If your water is not visibly 'dirty', why are you filtering it? If your water is visibly 'dirty' don't use a disposable filter, use a backwashed filter.
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Hot water tank drained - now whole house filter clogs easily bgalizio Plumbing 16 04-19-2009 06:46 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 08:11 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
Above Ground Swimming Pool Filter Tank twaters12 General DIY Discussions 2 08-13-2007 07:06 PM
